Originally posted by Gooshin if you think my equations are wrong, you can write to the author of that website and tell him that hes a hoot.
Hi Gooshin. No reason to quote a website here. Apertures are named f/5.6 (for instance) BECAUSE this already IS the equation! (E.g., with e.g., f=50mm, the aperture is 50mm/5.6 or 8.9mm)
Originally posted by BBear What are you trying to say here? The field of view I understand. I am having problems understanding what you guys are saying in regards to DOF x Aperture x Crop Factor.
You basically have sorted it out already. As far as Field of View and Depth of Field are concerned.
However, there is a third consideration.
If you multiply both, the focal length AND the f-stop by the crop factor, you must ALSO multiply the ISO setting by the square of the crop factor (otherwise, the image will be terribly underexposed).
So, an ISO50 image, with focal lengths multiplied by 6, becomes an ISO1800 shot.
Now, you have a perfect imitation of the P&S image: Exactly the same Field of View, Depth of Field and Noise. The noise is the same because the sensor captures more light by a factor of the square of the crop factor which makes the pixel noise equal.
If however, you don't apply the crop factor to the f-stop, you end up with less noise and less Depth of Field.
The DSLR lets YOU make the choice (between shallow DoF and noise) whereas with the P&S, there is no choice.
