01-18-2016, 08:50 PM   #1
MadMathMind's Avatar
Flash Exacerbate Moire?
So I had never seen moire with my K-5 IIs except in rare cases. I've since moved to off-camera flashes and wow...I see it a lot in my fashion/cosplay shoots now. It's become pretty common. Does the flash make this effect worse? I'm shooting at narrower apertures than before, about f/4 instead of < f/2.8 like I used to. I thought moire was supposed to decrease with smaller apertures. My photos are *a lot* sharper than they used to, of course, but the moire is become more and more common.
01-18-2016, 09:37 PM   #2
aleonx3's Avatar
If you use flash, it is likely that the images are sharper because flash seems to be able freeze motions. I also think that moire is more prominent in sharper images, in addition, when the image is shrink to small size, when it is full size on my screen it seems to tone down a bit.
01-18-2016, 10:43 PM   #3
Digitalis's Avatar
QuoteOriginally posted by MadMathMind Quote
welcome to one of the many challenges involved with studio photography! One of the major contributors to Moire is hard and contrasty lighting. Studio photographers like me don't just use big modifiers because the look cool - the softer shadows reduces contrast and and help reduce the impact of moire. The angle that you are photographing your subject also has a significant impact, straight on shots tend to reduce it rather than shooting on an angle.
01-19-2016, 08:21 AM   #4
As you head into diffraction land, sure. Going from f2.8 to f4 is moving into sharper land, which is where moire hangs out. Likewise for the possible extra motion freezing you're getting with the flash compared to ambient.
01-19-2016, 08:27 AM   #5
Also if you are shooting a lot of clothing, you are bound to run into Moire once in a while flash or no flash.
01-21-2016, 05:57 AM   #6
Thanks everyone! I don't like studios much so we do location shoots. My first time doing off camera flash had too much flash and not enough ambient, so I'm going to look more to f/2.8. That should help with moire just a bit because as good as the FA31 is, it's just plain ridiculous at f/4 and above.
QuoteOriginally posted by aleonx3 Quote
Sharper, yes. Unbelievably sharper, to the point where I finally learned what my equipment is capable of.
Just when I thought life was about to get easier!
QuoteOriginally posted by hjoseph7 Quote
I've seen it before, of course. Microfibers and spandex, which are incredibly common in my genre, cause the most problems. Satin is best for moire but the camera has a terrible time with the colors and texture. It really crushes it sometimes, especially if the dress is black or red.
apertures, common, flash, photography
Moiré with the K3. VE2CJW Pentax K-3 12 04-07-2015 04:54 PM
Fixing moiré from K5IIS skyoftexas Pentax DSLR Discussion 3 02-10-2015 09:50 PM
K5 IIs Moire mattt Pentax K-5 7 01-17-2015 01:32 AM
K5IIs moire question got2bNC Pentax K-5 3 07-03-2014 09:42 AM
Moire Removal nomadkng Digital Processing, Software, and Printing 2 02-20-2014 02:23 PM
All times are GMT -7. The time now is 11:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
