I was browsing another forum that has a small photography group and started to read a thread asking people what "mode" they used their digital cameras in. The original poster was basically curious about how much of the camera's automation others used. By the time I started reading the thread (about 8 hours after the original post) it had degenerated into a discussion/argument (mostly argument) between people that:
- claimed "anyone using automatic 'anything' was a camera holder and not a photographer, they always used 'manual' modes for everything" - true photographers don't need all the gadgets viewpoint, and
- those that "used camera automation as a jumping off point for being creative" - the camera is a tool viewpoint.
So, without getting into a shouting match - Does camera automation make you less of a photographer and you think manual everything is the correct way to go, or do you think automation complements you as a photographer and you use all the tools a modern camera provides to you?
What's the opinion here, and why?
I'll start with my opinion:
To me, the camera is a tool and I use everything I paid for to make my life easier when I take a pictures. It allows me to work on composition first and then the process of how I want to take the picture second. Both are important, but a well composed picture that catches the right moment in time (as I want to present it) takes precedence every time for me. The mood set by exposure is critical as well, and that's where knowing what to expect from the camera in a given circumstance comes in to play but I prefer to use more time on composition and the "moment" than on exposure. Exposure I can work with to a greater extent in post-processing than I can composition so I do rely on exposure automation to a moderate extent. I may make adjustments as I think appropriate for a given scene and how I understand my camera will record that image, or I may not. How much time do I have to do all this before the right "moment" passes?
Here's why I think that way:
To begin with, I don't think anyone really uses a modern camera in truly manual mode anymore. If they did they would be looking at a scene and basing exposure settings on experience or by using a hand held light meter, like I did 50 years ago. I used to be really good at estimating exposure settings by evaluating a scene before even looking through the camera view finder, to me that's "
manual" mode. Now I'm not as good at estimating exposure off the cuff as I used to be, you have to keep practicing a skill or it declines, I don't practice it as much as I used to. Today, I think that when people refer to
manual mode they usually mean using the integral light meter and adjusting aperture and shutter speed manually to achieve the look they want but still rely on the metering system for proper overall exposure. Maybe this should be referred to as
"semi-automatic" shooting. Autofocus is a little different, most people can focus pretty well manually and find autofocus convenient.
As someone who started taking pictures with cameras that had no integral light meter (1940's vintage 120 roll film, 1950's vintage range finder 35mm, and 4x5 view cameras) and moved into 35 mm film cameras with match needle meters then to auto exposure then autofocus film and finally modern DSLRs, I have a very good appreciation for the meaning of manual and automatic camera settings. One of many reasons I changed/upgraded cameras over time has been the improvement in automation and how much more convenient it is. Later, in my 40's, I upgraded because I just can't see well enough to focus properly and autofocus meant I could keep taking pictures. I still use a manual focus 35 mm, the autofocus 35 mm and even the 4x5 view camera (with hand held meter) so I can still appreciate the differences between technologies, it just takes a lot longer to get it done.
With that background, the one thing I learned very early on is that to record a good image you need to understand the whole process of photography. By that I mean you need to know how it all works: film (sensor) selection, how the camera handles, exposure settings, development (post processing) and printing. The same process of understanding how things work together applies just as much with modern digital cameras as they did 50 years ago when I started. So every time I've upgraded my camera I've taken time to learn what it can, and can't, do and how it all works as a system so I can intelligently work with the camera to make it do what I want. I may use the auto exposure settings or I may not, but I rely on them as a starting point. This only addresses post processing and printing by reference, which is another critical part of the whole creative process and is just as contentious as what camera is best discussions.
In the end, when I press the shutter release the image I record is based on my mood at the moment, the vision and experience I bring as a photographer to composition and exposure, and how I present the image to others through post-processing and printing. It's not because I just held the camera and let it do all the work or because I tweaked every possible setting for every image, it's because I decided what I wanted the tool I had in hand to do for me.
And with all that said, sometimes I take a really pleasing picture (to me) and plenty of times I don't, I'm still learning.
So, what does everyone else think?
Reason: corrected spelling
