Hi,
I've been experimenting with trying to taking macro images with "what I have", i.e., with various parts that I have, and I was kind of surprised/happy that I was able to use the following with my K-r:
- A 55mm f/1.8 M42 lens
- A reversing ring (49mm-to-something (I think it was a T-mount)
- A T-mount-to-M42 adapter
- An M42-to-K-mount adapter
Here's a pic that I was able to take with the above arrangement:
I figured that since that worked, I'd try to use a 135mm M42 lens I had, but when I tried that, it seemed like I could not get that arrangement to focus anywhere, either close or far.
I guess that, at the beginning of these "experiments", I assumed that if I got the configuration to work with one lens, that any lens would work, maybe with different closest focus distance and magnification, but that it would still work (== be focusable).
So is that "normal" that when using reversing a single lens, that only some lenses would work? Did I just get lucky with the first try with the 55mm lens?
What kind of setup might give me more focus distance but approximately the same magnification?
Thanks,
Jim
