Hi,
So I don't know if anyone uses 3D modeling software like Rhino (if you happen to be a designer on top of a photographer), but I've built this tool for visualizing your field of view and depth of field.
I made it for a more smooth visualization of the relationships of DoF to focal length and field of view. Helps me start to intuit how making changes would affect my photograph. The program is great because instead of punching numbers into applet boxes, you get all the parameters on sliders so you can go nuts cross-referencing settings.
I'd like to add a function that allows you to enter desired parameters for a "Brenizer" panorama... You put in the lens angle you want to simulate, and how thin you want the DoF, and it shows you how many shots you would have to stitch together, at which f-stop and focal length, from how far away. I would even build in parameters for how much you are comfortable overlapping your pano shots to help with stitching.
If anyone actually uses Rhino/Grasshopper, I'd be happy to share! Porting this to a web platform is currently over my head, but who knows...
24mm f/1.4 subject @ 10ft
85mm f/1.4 subject @ 10ft
200mm f/11 subject @ 48ft
