There's been a huge amount of discussion and research fairly recently here on PF, following on from my first edition of my Guide .....
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/302328-pentax...nt-thread.html
The conclusion from all of that was that the primary condition for P-TTL was in fact
autofocus capability (plus of course the aperture coupling as referred to by clackers above).It is the 'type' of lens, its technologies, that matter, not the manufacturer, so long as it is a KAF mount lens.
I believe the camera manuals that refer to 'A' series lenses are misleading ..... this compatibility will apply to only F & FA type lenses (which are 'A' types also).
Pentax have clarified things further in their AF-360/540FGZII manual which states that P-TTL is only compatible with
Autofocus Lenses.
---------- Post added 07-03-16 at 18:08 ----------
Originally posted by Blacknight659 I just had another thought.... I mostly had issues when I used bounce flash with My Metz 44 AF-1. I wonder if PTTL is disabled when I point the flash head away from the Front facing position....
Does anybody know about this?
Bounce does not disable P-TTL ...... have you checked out the demo thread I linked to earlier here ... ? That shows P-TTL bounced flash mixed with ambient lighting, and details exactly how it is done, with photo examples. I have not experienced any poor or eratic P-TTL exposures with the K7 and Pentax AF-540FGZ (I & II) models. Bounce may have added to the variables you were dealing with and added to the chances that you were exceeding the limitations of things as per your various configurations, settings and distances.
I have heard plenty of reports from Pentax people saying P-TTL is unreliable with the K5 (and many assume the K7 must be affected too) .... my response is that it is often hard to pin down the exact cause of these experiences, as the location, shooting circumstances, distances, understanding of the flash system and the physical limits, user experience etc are all often so variable.
You may have had power limitations with the Metz 44, depending on the bounce distances, surface reflections, ISO and aperture combinations .... ?
