For me, improvising like this is perfectly valid. Not that I'd do thus regularly to save cost, but imagine you forgot your reversal ring, it doesn't fit the only lens you brought or whatever would cause you to miss that shot of an outstanding small object!
A quick proof on concept using the DA50/1.8, very first macro object that came to mind. The 52mm thread fits within the locking pin circle. Of course it helps to have an aperture ring. On the DA50/1.8, your left forefinger will have to handle the aperture lever while the other fingers hold the lens flush to the mount and your left palm supports the camera. Attached example from the DA50/1.8 hand-held reversed, aperture opened approximately half-way: flowers of some
salix variety. Nothing to complain about in terms of quality, no dirt in the camera, roughly same working distance as with a 50mm macro.
Of course, it helps if you actually read the description of the picture:
Quote: This photo shows the lens held out from the camera so you can see what’s happening, but you’ll want to hold the lens right against the camera for this to work.
