07-08-2008, 12:22 PM   #1
Slick's Avatar
Light Meter Recommendations
Hi all,
Just wondering if anyone had recommendations for light meters. I'm going to get one to use with my MF system (Mamiya 5645 1000S). It has the metered prism that seems to work pretty well but I figure this would be a good excuse to get one and learn how to use it. I'm thinking about getting a Sekonics L-358. It seems to do most everything i need.
Any suggestions, comments, or advice?
Slick
07-08-2008, 12:45 PM   #2
literary device's Avatar
Hi Slick,
I have the L358M and it's an absolutely fantastic light meter. It does not, however, have spot or flash metering, so you should consider the L-508 etc. if flash photography is something you want to pursue.
07-08-2008, 12:54 PM   #3
Slick's Avatar
Thanks for the info. I thought there was a/an attachment(s) for spot metering. I looked at so many today it's hard to remember now. I'll check out the 508 as well because using it for flash photography would be important.
Slick
07-09-2008, 05:58 AM   #4
Mike Cash's Avatar
Perhaps not the best for your intended uses, but I love my Sekonic L-208. Comes with a hotshoe mount and is small enough to easily fit in my pants pocket. Easy to use handheld or mounted on a camera.
07-09-2008, 12:03 PM   #5
Slick's Avatar
Hi Mike.
I looked at the L-208 at first but, of course, I kept looking at the next model up, and so on, and so on...
It is a nice one and would probably work fine for me.
Still trying to decide and thanks for the recommendation.
Slick
07-09-2008, 07:12 PM   #6
heatherslightbox's Avatar
Last fall when I took a photography class, the instructor highly recommended the L358. I haven't gotten around to picking up a meter yet, but if I was to get the L358, I'd most likely see if I could pick it up used off of Fleabay, as I'd rather not pay over $200 for a meter, new or used. As I was looking at the Sekonics, another model that got my attention was the L308s, which is just a step below the L358. Brand new, it costs less than $200.
Sekonic | L-308S Flashmate Light Meter | 401309 | B&H Photo Video
It gets high ratings from users on B&H, so it is definitely a contender for me.
Heather
07-10-2008, 01:46 AM   #7
Slick's Avatar
Hi Heather.
The main problem for me right now is deciding if I need/want spot metering capability. The main reason I was looking at the L-358 is you can add spot later. It costs another ~$150 but at least the option is available. The L-308 does look like a good meter, though.
I'm not too worried about cost but I'm not going to spend a bunch of money on one since I don't know how much I'll use it. I travel internationally for work and don't bring my MF stuff with me (usually) so typically it would only get used a few times a year.
I'll probably go with the L-508 now that I've looked a little more. At KEH the L-358 (new) is ~$250 and the L-508 (EX+) is ~$310. If I add the spot meter attachment to the L-358 the cost goes to ~$400. The L-508 has spot already.
Slick
camera, light, light meter, photography, recommendations
Help with light meter srpickel Troubleshooting and Beginner Help 6 02-18-2010 03:49 PM
Using the K-m light meter - if it has one kitkat Troubleshooting and Beginner Help 14 07-11-2009 06:23 PM
Light meter recommendations? heatherslightbox Pentax Camera and Field Accessories 11 05-26-2009 09:00 AM
Light meter recommendations navcom Pentax Camera and Field Accessories 0 03-22-2008 01:02 PM
Light meter recommendations? slip Pentax Camera and Field Accessories 1 03-28-2007 04:29 PM
All times are GMT -7. The time now is 03:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
