Originally posted by Paul the Sunman My question is: which camera and flash settings should I use? The K3 manual recommends using P mode for fill in flash with P-TTL. Is that the best choice? The light will probably be good enough for me to set ISO100 throughout, but I am still concerned that the 1/180 maximum flash sync speed will force me to stop down more than I would like for DoF purposes. I could use an 8x ND filter on the DA70, but don't have one to fit the other lenses. I could also use HSS (supported on the Metz), but this reduces flash range, so it may not always be possible.
I'd gladly go with P mode and P-TTL for daytime outdoors fill flash work. And I'd also go with auto ISO but that's just me.
If it's sunny, aim for backlit shots with -1/3 or -2/3 exposure compensation. That will reduce both the ambient and the flash exposure.
Also consider using a 1/4 CTO gel on the flash to give people a nice tan.
If it's overcast, set -1 to -2 flash exposure compensation for just that slight touch of fill flash to brighten up the faces. Don't gel the flash.
On ND filters versus HSS, they rob you about equally of flash range. The only way to gain flash range shooting into the sun is with
faster sync speeds. Or more flash power of course.
Regards,
--Anders.
