Good comments here. Do learn the constellations, there are plenty star chart programs out there, I like K Stars. Originally developed for Linux it was ported to Windows a while back.
https://edu.kde.org/kstars/
Here's how I find Andromeda.
Find Cassiopeia. At one end is a triangle of stars. When Andromeda is visible it should be a the top. The star on the right points almost straight at Andromeda. Follow that imaginary line to the right until you get into the next constellation, I can't remember its name but it's basically a large rectangle. If you find the two end stars of the lower line, Andromeda is about 1/3 of the way from the end furthest from Cassiopeia. On a dark night, usually in the dead of winter, you should be able to see it with the naked eye as a fuzzy spot in the sky. Once you learn what those two constellations look like, it takes about 10 seconds to find.
At the other end of Cassiopeia is a cool star cluster named the Double Cluster. Not hard to find, sometimes barely visible by naked eye as a fuzzy spot. I haven't tried, but it might be possible to get a picture of it too. Not hard to find with a telescope though.
Another interesting one might be the Hercules Cluster, I thought it was a star cluster then found out it's actually a galaxy cluster. Look for it in a star chart program in the Hercules constellation.
Another very interesting one, and probably the most photographed deep space object, is the Orion Nebula. It's in the Orion constellation, one of the easiest to identify. Look just below Orion's "belt" for a group of stars in a straight line pointing mostly downwards, the "sword". The nebula is right there. I found it by accident star hopping one night, thought I had a smudge on my lens. Cleaned the lens and it was still there so I looked it up in Kstars...
Planets are actually more difficult to find, but once you learn their path, it's easier. Planets follow the same path, and it's the same path as the moon. Learn where the moon rises and sets, the planets all follow that same basic track. Some are easy to spot, some can only be seen with a telescope. Jupiter, Venus and Mars are easiest. Jupiter and Venus will often be the brightest objects in the sky except for the moon, and Mars has a reddish tint. Don't expect to get a sharp picture of Venus, it's too close to the sun and surrounded by clouds, I've never gotten a sharp view of it with my telescope. Mine is a 6 inch, I've looked with a 8 inch and a 12 inch, always fuzzy no matter what lens I use. I found Saturn by accident star hopping too, it was much closer to earth than it is now, and as bright as Jupiter, I thought I'd look at that bright "star"...I had also just changed lenses, so I had to refocus. As I got close to focused I realized it was oval...what the??? It turned out to be Saturn. It's very impressive. I was at a friend's house, just showing him around the sky a little. Moon, Orion, simple, basic stuff. I barely knew my way around a little. After seeing Saturn, he was looking for a telescope the next day...
