Originally posted by fromunderthebridge That sounds a bit like as if you are implying that with the advent of digital, we finally have a 'standard' which frees us from the subjective processes of image making.
No. What we
do have is a set of standards by which we can communicate to others exactly what happened to the strings of ones and zeroes between the time when the sensor dumped them into the processor and when the resultant JPEG appeared on the back LCD or the computer screen. FWIW I have a K-5, current firmware, "Bright" preset with all the sliders on default, and when I say "straight out of camera", that's the processing it's gone through.
Originally posted by PDL The standards that you speak of do vary quite a bit by manufacturer both in software and hardware.
True, but see my point above. If I specify what camera I use, what firmware I use, what presets I use within camera... then at least we can all agree on what has happened to that image. The fact that my K-5 does not treat things in the same way as my neighbour's D500 or
their neighbour's Olympus M4/3, or even the fact that a given version of Raw Therapee probably doesn't do particular things the same way as the current version of Lightroom,
is irrelevant so long as I can say what I did and with what tools.
It's a given that if I were to take a JPEG picture with a newly out-of-the-box K-1 mounted on a tripod and bearing (for example) my 55mm Rikenon wide open (f/1.2), and then gave that lens to the proud new owner of the latest Sony mirrorless FF wonder to put on his beast on the same tripod with a K adapter at the same aperture, shutter speed and ISO, that we would get somewhat different pictures. I understand that completely. But it doesn't take away from the fact that I can specify how that image was auto-processed in camera, and particularly specify what (if anything) extra I did to it before showing it to the world.
