You have a few options with your gear. Try the kit lens (I assume an 18-55) at the wide end and also try your 50mm.
Wide Milky Way images: 18mm, f3.5, ISO 1600, 25 seconds to start. Skip the astrotracer for your first few shots because stars won't move much at 18mm wide. You can then use the astrotracer with longer exposures.
For a closer view of the Milky Way, use the 50mm. Test it at f1.8, f2.0, f2.4, and f2.8. Some lenses give better looking stars with less distortion when they are stopped down a bit.
Focusing is important. Use manual focus, live view, and use a bright star. Recompose your shot after focusing. Periodically recheck focus through the night.
I suggest using DNG+JPG to capture data. The JPG files will give you an immediate result. The DNG files can be processed for much better looking images.
