I've often posted that 16 is the limit for functional APS-c images as opposed to 22 on a full frame. (Knowledge from years of testing, taking the same image at multiple exposures and selecting the one I liked best.) However those two are the same DoF so you aren't losing anything. You can use f-22 for 16 on your FA 50 when calculating DoF on the on lens DoF scale.
There used to be that rule "8 and be there". On APS_c that should be "5.6 and be there." Which works out really well for APS-c shooters, because diffraction starts to affect images at 8 on both APS-c and 36x24, meaning, you'll get slightly better sharpness using an APS-c camera at 5.6 then using a 36x24 sensor at 8, although the superior resolving power of the larger pixels will even that out. (We're discussing the same number of mega-pixels on both cameras.)
So for APS_c my rule is "5.6 whenever possible" and single step up from there until I have what I want, keeping in mind, every stop after 5.6 gets a little bit softer, and often, so does every step to a wider aperture as well as well.
But let's not go so far as to say 22 images are completely without merit. ( I hate these freakin know it alls. I completely fail to understand why some freak can sit in has living room watching the ball game, have a random thought, and then post it on the internet as if it has some kind of meaning. That's what it seems to me, many of them do.) ) On some occasions, -22 produces the best image, even though maybe not razor sharp. Sharpness is a bourgeois concept. ( or to be more polite, images do not need to be razor sharp, to be good images. The sharpness needed by an image is dependant on a number of variable circumstances.)
Norm
Out of 20,000 keepers on my hard drive, about 40 are shot at 22, and every one of those was selected over images that were shot at theoretically "better" apertures.
Pause for thought here, if I hadn't taken the time to shoot at 22, I would have missed out on what in the end, was the best image.
I simply don't take images just at 22. My expanded sequence is 2.8 or 4 (not all my lenses open to 2.8) , 5.6 , 11, 16 or 22. My usual sequence is 2.8 or 4, 5.6 , 8 or 11. I have no doubt I'd have more 22 keepers if I used my expanded sequence more. Honestly, if you think 22 might work, give it a go... these book writing dudes don't know everything.
Note:.. all these images look good large, and pixel peeping , don't even try and do the "well they look good at web size" thing.
Thanks for posting, it's an interesting topic.
