Originally posted by Mapleleaf-Mick Thank you SeaRefractor for that excellent info. That is exactly what I was looking for. I have a Tokina 400 F5.6 I wanted to try as well as the Bigma but it sounds like they are to slow. I ďo have slower F1.8 lenses that I could try. Primes are the way to go I would expect. Nothing under 20mm for wide angle?
400mm and f/5.6 isn't entirely 'senseless'. I regularly use my catadioptric 350mm f/5.6 lens together with my K-5 and K-3 plus the O-GPS1/Astrotracer. You just have to realize that accurate calibration becomes ever more important with increasing focal length and you must expect your success rate to drop accordingly. You can see some of my results with various lenses here:
DSLR Astophotography: Astrotracer Images with Pentax GPS Unit O-GPS1
(And note that I have gone up to even 700mm f/11 with some success on rare occasions).
If you are a pixel-peeper and if you go below some 20mm in FL, you will notice that stars become stretched as you move away from the center of your images. This is because Astrotracer can only move in up-down and left-right steps and rotate along the optical camera axis. Thus, unlike a camera mounted on an equatorial platform, Astrotracer cannot ensure that the sensor 'tilts' in order to retain its posistion relative to the position on the celestial sphere where the optical axix was pointing at the beginning of the exposure.
Overall, I should say that Astrotracer works best with lenses in the 24 - 200mm FL range - but do experiment with what you have to gain your own experiences.
Originally posted by Mapleleaf-Mick Very very interesting and informative. Thank you very much for taking the time and effort to respond. I have lightroom but to be honest I am a bit afraid of "stacking". Don't know a damn thing about it. As I mentioned previously, I have a number of good Pentax primes 35's and 50's @ f1.8 or so which may do the trick. I really want nebula or planetary pics versus just star points in the sky. Maybe I am being overly optimistic with the gear I have and the experience I possess.
Michael
If you want nebulae more than Milky Way panoramas (which can be very rewarding in itself) then you do have to consider longer focal lenghts (from, say 135mm and up). Again, please refer to the sample images I have linked to. If you want planetary detail more than Jupiter with its 4 moons as tiny 'dots', then you are in Telescope Land. In all immodesty I can point to my own homepage again:
Camera Settings for Astrophotography
- and whether you are afraid or not, you WILL eventually have to venture into stacking. And it really isn't that 'terrible' after all: Just load your pictures into a program like Deep Sky Stacker; ask the software to do the stacking and then use some sliders to darken/lighten your resulting image until you see your target. After that, you may undoubtedly want to look into the refinements. A starting point could be this tutorial:
Deep Sky Stacker
Have fun with your venture into the many-sided aspects of Pentax DSLR Astrophotography!
