Okay, here's some of the stuff from last night, and it isn't all that good in quality, but I am sharing it anyway.. It tells me I needed to get the counterweight set right (duh, knew that) because the tripod was partially in the way (maybe a new, dedicated tripod too., causing things to be off balance and it to mess with tracking some, that I need a 77mm Bahtinov mask for focusing or to prefocus in the daytime and tape the focus ring down like I normally do, and that I really need my 150-450 to come back from being repaired again ASAP. So, last night's play with the new mount results are in and I need to work on my technique a little, but you get the Crab Nebula, parts of the Orion nebula complex (Flame Nebula, De Mairan's Nebula, Orion Nebula, Horsehead Nebula, part of Bernards Loop), Pleiades, M41, Sirius, and what I think is NGC 2360. Enjoy, and look for much better results in the future!
In case you're wondering the mount is an iOptron Skytracker Pro and the counterwweight kit is the iOptron 3311 (not the right one for the kit, but it can work with the right adapters, yeah, I was stupid in ordering it) and a generic ballhead from Amazon. I think once I get things set I can probably pull off 2+ minute exposures. The most I tried last night were 20 seconds, which when the camera was facing south ended up good, facing off axis, not so good at times due to the setup being a little off balance.
So, if anyone has advice in allowing the nebulosity to show, but minimizing clipping highlights I'd love to know. Also, how to keep the noise out, because these have fields of grain in them. Also, critique my technique because frankly these pics suck compared to some I see, and I want to get on their level, plus I can get a glimpse of what this setup is capable of when done right. All images taken with a K1, Tamron 70-200 f/2.8, and DA HD 1.4 Teleconverter. I really want
