Hello guys,
New to the forum, big time Pentax camera fan and user.
I recently got into macro shooting, close-up crystal/glass work that my wife makes on her free time, and dental/intra-oral shooting for my own practice. Here's my equipment: K20D + Pentax 100mm Macro WR f2.8/Tamron 90mm Macro + Yongnuo YN-14EX ring flash. Normally I have my setting at M/f22/1/125 ~ 1/160, and ring flash at ETTL or M. My biggest problem is that I'm getting a pretty bad over exposure (or under) with the same setting, under different angle or environment. Say when I'm taking a close up front teeth (when the teeth are closed), the photo will come out fine but then when I use a metallic mirror to take intra-oral pictures, most of the time I will get a very dark result, as if the flash didn't flash at all or wasn't syncing correctly with the camera.
After tweaking the setting for half a month I'm still not able to get the right light, right exposure for my work. One of my colleague uses Canon eos 400D + Sigma 105mm + Sigma EM 140DG ring flash and he's getting the right exposure like a piece of cake, just point, focus, shoot, boom, perfect photo. Now I'm stuck with switching the setting manually every time when I shoot from a different angle, it's frustrating and time consuming, and I have to take off/put on gloves and pause my work in between because I didn't want to put my assistant through the hassle with this camera.
My research shows that the Yongnuo YN-14EX ring flash (China brand) is only good with Canon ETTL, but no luck with Pentax PTTL, and I have to manually set the flash intensity differently each time. So far I've found three ring flashes that supports PTTL and may be capable for my work: Metz 15MS, Pentax AF160FC and Sigma EM 160ED (for pentax), are there no any alternatives? Despite from the high pricing factor, it's quite difficult to find these flashes here in Shanghai (currently residing and working oversea).
Has anyone had experience working with the Yongnuo YN-14EX ring flash and can perhaps give me some advises on the setting? I'm very new to camera flashes, still doing ongoing research about it, and I want to keep using the K20D since that's my wedding gift. Thanks in advance, any advises, greatly appreciated!
Jeff
