Originally posted by AstroDave Do you really need DNG files? If your goal is to make this into a movie, you will be downsizing all the frames, and don't need all that much detail. If you shoot jpeg, you can get 2 or 3 times as many frames on your SD cards. Also, unless your Tamron is sharp wide open (you'll want it that way for the night shots(?)), your images may not be that sharp to begin with with - again a waste of DNG capabilities.
In this case, the advantage of DNG may be the ability to play with white balance--going between night and day there will be a big change in the quality of the light. DNG gives you flexibility in adjusting for that.
