Originally posted by BrianR Do you have an example of what you've tried so far? Below is a pretty simple photo to show the aperture shape and size (also the dust and grime on the lens
). Just a reflective umbrella up close with something light behind. Add more relatively large light sources around the front (more umbrellas or softboxes, or even use a light tent with the front curtain pinched in) and you can uniformly light up the front assembly, the reflections of the light sources won't obscure the aperture shape if the aperture is backed by white.
It depends on exactly what you're trying to show though (there's no detail on the aperture blades in my example). Another option is to use a couple sets of lights, one to show the front assembly, one to light the aperture and blades how you want. Two photos, one with each light setup and combine in post. This would be a fast edit, but might look odd if the viewer is paying attention to the lighting.
Thanks, Brian. Unfortunately, I don't have the test shots I took - I wiped them while they were still in camera, before I sent the body off to the UK Tamron distributor to calibrate my Tamron 10-24 lens
I'm trying to show just the front of the lens (for the trim-ring markings), and the shape of the aperture at each setting, to demonstrate how that shape changes. A number of the lenses I'll be photographing have interesting star-like apertures when stopped down a little; others - mainly telephotos with a large number of blades - remain almost perfectly circular. It's of interest in terms of out-of-focus rendering.
I'm thinking the pinched-in tent with two flashes, each firing at a front corner of the tent (to fully light up the diaphragm) might be the way to go. I'll set my tent up and give that a try tomorrow, I think.
Originally posted by Kerrowdown Here's a thought... what about one of those wee diffused light tent/cube thingys... would that do it?
Thanks, Kerrowdown... see above
