Originally posted by kmladeno I focus with half-presiing the shutter and lock the exposure using the AEL/AF button. A star (sign for AEL) appears but EV continues to change while I am recomposing the scene. Is that normal?
Yes, it is normal.
In M mode, the camera will use whatever shutter, aperture, and ISO setting you have chosen regardless of what's happening with the changing EV bar graph.
The best way to think about the EV bar display is that it always shows you the difference between the current camera exposure settings and the current light meter reading.
If you use the spot meter and AE-L but then recompose, the EV display will change to show how many stops over or under the current object under the spot meter is relative to the locked settings. It's actually a great way to double-check dynamic range such as checking that bright clouds aren't going to clip or that shadows aren't going to be too dark. When I use the sport meter, I lock the exposure settings and then take a quick tour of the scene just to get a feel for the range of tonality in it.
Overall, when you are in M mode or in any of the auto modes with AE-L, the EV display fluctuates because the camera settings are fixed but the meter reading might change as you recompose or your scene changes. In the auto modes (before you push the AE-L button), the EV display is fixed and set to the EV compensation value because the camera settings move up and down to track changes in the meter reading.
