07-25-2017, 11:51 PM   #1
Any camera setting that can help the flare ?
I have the K1 and lately I shoot with some old Tamron wide angle lens. The lens had flare problem and
I understand adding a hood (not easy to find a proper one for wide angle) or step down will help.
I like to know is there any setting in the camera can further help the issue if I need to shoot in strong light with the lens, thanks.
07-26-2017, 12:11 AM   #2
You could try shading the lens from the light source with your hand. A suitable hood will be best, leave off any filters and shoot from shade if you can.
If your light source is in the image you will get some flare whatever you do.
07-26-2017, 12:13 AM - 1 Like   #3
BigMackCam's Avatar
Flare is a physical effect of light source and lens design. All lenses will suffer from flare to varying degrees, depending on the strength and position of the light source. There's no setting on any camera that can prevent it from happening - but using the correct hood for the lens will help. Also, you can position your hand between the light source and the edge of the lens. Veiling flare tends to reduce contrast significantly, so increasing contrast and clarity when processing an image can improve things, either by applying it it to the entire image or using the graduated filter tool. Finally, sometimes you just have to pick a different shooting position
07-26-2017, 01:42 AM   #4
Also, try adjusting your composition to minimize the flare, since in some parts of the frame (often corners or edges) it's worse than others.
07-26-2017, 06:00 AM   #5
Na Horuk's Avatar
QuoteOriginally posted by micl161 Quote
Get a tighter lens hood? I remember there used to be this soft thing you could add above the lens, looked like a horn, which would shield the lens. But I think it took too long to set up and Im not sure what its called.
Some people use a step down ring instead of a lens hood. But you have to be careful not to get a step down ring that is too small, or it will act as an aperture or cause vignetting. It might be better than a third party hood, though
Yes, using aperture like f8 usually means less flare than wide open aperture. But going above f12 or so starts to cause diffraction, and sometimes you want faster aperture for shallow DoF.
Holding your hand or a hat above the lens is a simple solution, though it might look a bit silly. An be careful not to dip your hand into frame!
07-26-2017, 06:19 AM   #6
Looks there is nothing can do on the camera setting but try the best (hood or whatever) to block the light,
anyway, thanks all.
07-26-2017, 06:53 AM - 1 Like   #7
photoptimist's Avatar
1. A lens hood, a card, or your hand is the first line of defense.
2. A very clean lens and filters (or no filters) can help. (If the lens has internal dust, haze, or fogging, then that's going to make #1 even more important).
3. Narrower apertures can help minimize the size of flare bubbles and may reduce overall flare somewhat.
07-26-2017, 07:47 AM   #8
Na Horuk's Avatar
The final thing you can do is shoot raw and learn Photoshop to remove some flare digitally
07-27-2017, 05:32 AM - 1 Like   #9
Kozlok's Avatar
One of those flexible lens hoods may work for you
Flex Lens Shade Flex Lens Shade A001 B&H Photo Video
angle, camera, flare, lens, photography
MC MIR-20M 3.5/20 - blue corner flare on full frame. Any ideas? BigMackCam Pentax SLR Lens Discussion 8 02-02-2017 10:26 AM
Help setting up off camera flash Homo_erectus Flashes, Lighting, and Studio 9 10-05-2013 08:38 AM
Setting Sepia setting in camera? PBandJ Pentax K-01 1 02-09-2013 06:17 AM
Really strange flare - any idea what caused it? Sagitta Troubleshooting and Beginner Help 18 04-15-2012 06:56 PM
HELP! The Nagging Question...Is it real or is it LENS FLARE? chefpete1 Photographic Technique 9 03-03-2011 10:01 AM
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
