Originally posted by Pentax_WA Please take a look at these photos and let me know if they are sharp to you.
As far as I can tell, and I did look at your samples on flickr, in all but #4 you achieved critical eye focus, as usually desirable in portraiture, whereas #4 is focussed on the tip of her nose. Which doesn't exactly cry front fous issue (unless you had a great number of misses beyond the samples). The Tamron, as is often the case with dedicated macro lenses, is even clinically, almost brutally sharp. Whether you like that for feminine portraits is a matter of taste or of your goals in portraying; too much honesty can be offending to subjects. (Don't get me wrong, I happen to value honest portraiture.)
Some of your doubts about correct focus may stem from the shallow DOF you are seeing. At your chosen apertures, depending on your model's pose, it is only to be expected that little else than her eye(s) are in focus. Which is why some photographers would be willing to sacrifice a tad of killer bokeh to expand DOF a little.
OT: Yep, (as others have observed) exposure and lighting are noticeably inconsistent, not always flattering, and I, too, would have tried to use more off-centre AF points to improve composition.
