Originally posted by RaduA Creampuff,
With all due respect the whole discution gravitates around HIGH RES FF sensors, not the 12-16 Mp tops of D3's, 5D's or 1Ds MarkII's. The examples from the review show what happens with a 21 Mp sensor and the next gen seems to be in the mid 20's range so even more demanding.
Radu
1) The 21mp sensor is less of a high res sensor than the 14,6mp in the K20D; it is just larger. From a resolution point of view, the K20D puts more demands on the lenses.
2) APS sensor, like the K20D, sets even more demands on the quality of the lenses because the format is smaller. Compared to FF, all optical defects - including purple fringing - are 50% more for the same lens for a certain output size.
3) What is a professional opinion anyway? Someone having opinions as a profession? Thousands of pros use older lenses on FF Canon bodies with good results. Thousands of pros use even older, even worse lenses on medium format camera with digital backs. The results are spectacular.
4) The argument in the original article was that you need to use the best lenses to get the best out of the sensor. Wow!! What a surprise! This is true for any sensor film or whatever. It is even more important the smaller the format is.
5) This post was also made at the Dpreview list where it was debunked....
