Easy way would be to reverse a M42 lens , or a M39 lens or any screw mount lens ( just about )
That way you could screw on a M42 adapter to what ever thread you needed and put your ring light on that .
I dont know if there is a Kmount to screw adapter . (?)
ACTUALLY !!!!! Those cheap chinese tubes .. They actually come apart ..
So you should be able to dis assemble the tubes , and the part that takes a lens .. Well put it on the reversed lens and then see what adapter can screw to that ..
Let me check , I have those nasty tubes ..
---------- Post added 08-16-17 at 08:23 PM ----------
Looks like 60mm thread .. ( Should work just fine )
