Originally posted by TER-OR I've been using Manual mode with a flash in manual mode at 1/4 power. ISO 200, f16, 1/160 sec
I could probably go tighter on the aperture, but f16 seems to be working well for me.
Its all about what works ..
Aperture is so (?) , depends on what lens - working distance and the end result you want .
And for some strange reason there seems to be resistance to working in the higher F stop range (?) , it has always surprised me when people leave comments like ( I didn't know you could use F32 ) .. ??????
What would they think about using F64 ?
Anyhow , that might be considered more advanced stuff .. ( Maybe )
4th day of spring here , and the weather is wild and wolly .
Camera settings : A lot of people start from what I would ( my perspective ) consider the wrong end .. Running High ISO - low Fstop and too slow a shutter ..
Anyone having issue taking nice clean sharp images (?) dont forget to include - ISO - Fstop and shutter speed information with your picture .
Seriously , we are here to help , not harsh your buzz !
About the picture I posted :
Lens is a Vivitar 55mm 1:1 Macro lens , F2.8 to F16 ( F16 is as small as the aperture goes )
Shutter speed is as high as it can be to use a flash , and the ISO is about right for the conditions ..
If there was more light I would drop the ISO to 100 and If there was less light I would possibly increase ISO to 400 or drop my shutter speed .. Just depends on the prevailing conditions ( like wind ) .. If there is movement ( beside your own ) to contend with , lowering the shutter speed could be a bad idea .
---------- Post added 09-04-17 at 02:54 PM ----------
Originally posted by Thagomizer What a great approach and a great way to explain it! I'll have to try this myself. I kinda do something slightly like this, but not in a terribly systematic way. This clarifies things wonderfully. Thank you!
I pre set my camera for the prevailing conditions ( light ) .
This way only minor changes are needed to maintain settings as close to what I want .
Macro is so variable , there is no one answer for everyone .. So unfortunately I try to be as general as possible , but hopefully in a way that gives direction or clarity for anyone that may be reading this ..
