Ok... so I'm using primes, I'm practicing lens swapping and the thing that slows the process down the most is the front and rear caps. Even with Optecs dual lens cap, the process is significantly slower.
There are a few videos on youtube that show people doing fast lens swapping, but I feel cheated as they are either in the kitchen picking up and putting lenses back down on the kitchen bench (without fitting caps) or one is actually in the field and doing a swap but then placing the lens in her bag without the rear cap on. This fact is touched upon and the justification is that it's fine if you know where the lens is, that nothing can happen to it and not bump another item etc... There's no doubt about it, avoiding any kind of capping action speeds things up significantly.
I have my first wedding shoot in a week or so, I shall be lens swapping a fair bit I imagine. I can't help feel the fluidity of the process as well as speed and success of the job (ie in getting those captures) would be significantly improved if I also adopted this 'non cap' attitude.
My set up is...;
COSYSPEED Camslinger 160 (Pentax KP lives in here with one lens attached, such as DA15mm)
Rock Climbing Chalk Pouches attached to this Cosy belt.
The chalk belts are where the other lenses live. Now it might be hard to see from the pictures but they have a draw string and further into the pouch the lining changes to being the softest felt material possible. I bought these as lens pouches as they seemed to be the best
value pouch I could find, a similar sized pouch from a different retailer are 2-3x that price and I don't like zip exits, I fear the metal zip could damage the glass.
Now of course if its wet then all of this is a different story altogether, but if the weather is dry, I'm entertaining the idea of not bothering to cap the front or rear of the lenses when swapping. The only thing in the pouches will be the lens, and it is super soft inside. I have a rocket blower attached to a strap, a couple of quick bursts on each side before attaching and I can't really see the harm? Obviously if I am somewhere sandy then I would need to pay close attention to what gets in the pouches, and in general transportation they would be capped. I'm talking about being mainly vertical and shooting on a job and not bothering to cap... am I mad? If the lens has a long hood, then keep it on, that also helps protect. Perhaps screwing on a generic UV filter to protect the lens glass is enough insurance at least for the front...
Do we have any 'non cappers' here? Is this a thing? Are we all too precious about such things? If a rear or front element does get scratched, is it an expensive thing to replace? Do we service lenses in this business also (for dust inside etc)? (I have only once serviced my camera body...).
Curious minds want to know!
Cheers,
Bruce
