If you just want to get to 2:1, then my choice for that is a Raynox DCR-250 on a 100mm macro. It's just much more convenient than shooting anything reversed (coupled or not), where you need to stop down the reversed lens and it can become very hard to see anything... (Some people shooting reversed lenses even add bracket-mounted flashlights to their setups to aid with focusing.)
But, for your question - which combo precisely if/when shooting
coupled reverse lenses - I'd opt for: 0) A prime for the primary (non-reversed) lens; 1) those lenses you have which you think are the sharpest when used normally; and 2) lenses that give you a combo that is the proper length to have good diffusion. I'm not kidding about that last point - good light is super important, IMHO. Whatever you best diffusion setup is - jerry-rigged DIY or store-bought - it will be appropriate for a certain length of setup. For me, for example, I'm setup to shoot with horizontal flash, so using a physically longer lens combo works better for me. If I wanted to shoot something very short (say a reversed 28mm by itself), it would mess-up my light, and I'd need to make a new diffusion setup. (So, for example, to get 4:1, I would choose to couple a 200mm and a 50mm rather than a 100mm and a 24mm.)
For lenses, in practice, we're blessed in Pentax land with a bunch of pretty good old primes to choose from. You can get an M-series lens in 85mm, 100mm, 135mm, 150mm and 200mm. For best optical results, probably get them all to use as primaries, get an old 28mm and an old 50mm for the reversed lens, then pick your exact combo based on the magnification you want.
On the other hand, for flexibility, I like to use a reversed zoom as a secondary, which allows one to change magnification on the fly based on the subjects one encounters. (It's better to use a zoom as a secondary, not a primary.) I've tended to use an M 135mm F/3.5 with a reversed 24 or 28 to 70mm zoom as a kind of poor man's MP-E - giving a workable range of 2:1 to about 5:1. (Be aware that at high magnification, diffraction can really hurt your shots though... ) I've been known to carry that pre-assembled in my bag, with the 100mm macro plus Raynox DCR-250 on the camera. That gives me fairly easy access to infinity to 5:1, with 0.8:1 to 2:1 as the main working magnification range (the range of the 100mm plus Raynox combo).
