I know this is a bit off the intent of this string, however after my original post I stumbled on to a Lensbaby Composer I Sweet 35 and have since added a Ketnor Digital Super Wide Lens adapter to the mix. When it comes to Tilt shifting the Lensbaby Composer I & Composer II along with any of the available interchangeable optics are the, pardon the expression "Cat's Meow".
Adding the lens adapter definitely brings it up another notch. Unfortunately adding the adapter severely restricts the Tilt Shift capacity of the lens and I can see freelensing the Sweet 35 Optic, possibly minus the Composer mount with its very narrow sweet spot at maximum aperture and the adapter attached could produce some very interesting results
The first is a shot using Tilt shift
The second shot is done with the adapter attached
