Originally posted by PaddyB Hi all,
Can someone give me a few pointers on how aperture and shutter speed interact in the above shooting conditions? Also, would I get pretty good results just shooting in aperture priority and letting the camera select shutter speed? Or, am I on the wrong track and need to just manually adjust my exposure value?
I don't think switching modes (P/Av/Tv) will have any significant affect on exposure. They are all automatic and will adjust one or more of the parameters to reach the exposure your camera thinks is right. There's a lot of other reasons to use Av or Tv though, such as control of depth of field and motion blur.
You might want to look more into adjusting the exposure compensation or changing the metering mode. For example, if you found that the picture is too dark, you can set the exposure compensation to +1 and retake the photo. Or you can set the metering to spot, point the camera at something medium gray, press the AE-L button to lock the exposure, then take the picture.
Some scenes with really bright areas and really dark shadows just won't expose very well regardless of camera setting. You may have to pick the best exposure you can and try to fix it later in post processing.
