Originally posted by microlight Hi Bruce.
Responses in order:
- I don't use LR as I don't need the cataloguing feature, and Camera Raw has all the bells and whistles. My PP is done in ACR, and with 4 or 5 images for super resolution, all get edited simultaneously. So in other words, I do all my editing before the super resolution conversion, although I suppose you could also edit the output TIFF, although I haven't done it this way. I don't think that this is one of the critical steps in the process.
- Don't skip the up-sampling to 200% - this is critical to the process. Ian Norman in his Petapixel article explains that the averaging process "will allow us to resolve detail at up to 1/4 of our original pixel size; so when we upsample, we increase the image to 4 times its original size". What this means to me is that increasing the image size gives the headroom necessary to increase the resolution - otherwise there's no benefit to doing this.
- I don't see the advantage of the Smart Object route (even though it only takes literally a couple of seconds on my PC for the conversion) as it takes very little time to adjust the individual layer opacities. Yes, for five images, the percentages you quoted are correct. This is a more intuitive step for me, without going throught 'black box' Smart Object.
- Flattening is the third critical step, after the upsampling and averaging, as otherwise your output TIFF is just too big, as you've found. It's under the 'layers' menu, at the bottom of the list, and is necessary even if working with a Smart Object, as the single object still has a stack of layers in it, as Steve noted. He's also correct about destructive editing being necessary, but it doesn't matter here because you're effectively doing it on a new file tab in Ps, and can therefore even remove the four or five unchanged DNGs that you originally imported into Ps as they're not needed any more.
So, bottom line is that you have to minimally carry out the upsampling, averaging and flattening to get improved resolution at a manageable size. I tend not to re-sample to 100% but keep the 200% TIFF as that's essentially my 'RAW' file for a picture taken using this technique. While slightly larger than a pixel-shift file, it's not something I do with every photo; in fact I only use it as a pixel shift replacement when I haven't got my tripod with me, so the extra storage space isn't an issue on a 2TB drive dedicated to photos. Hope this helps.
I hadn't thought of using it combined with HDR, but first thoughts are that it may not work, or if it does then the correct exposure may need to be on the bottom of the stack as this is the one with 100% opacity. As Steve indicates, get the super resolution bugs sorted out first, and once you have a reproducible process, suck it and see with HDR, it can't do any harm.
Excellent reply, thanks that's really helpful.
When I was first alerted to Super Resolution it was from a fellow I follow on flickr (a fellow Pentaxian) but also he is in the same Pentax FB group as well. I felt I pestered him enough so started this thread here to get more responses (and also alert others to this technique/idea, just in case they (like me) weren't really aware of it). He did hint that he uses HDR Stacking a fair bit, essentially it is always wise to capture as much RAW data from the site being photographed as possible, and bracketing does just that. But yeah, I have not pestered him to ask exactly his work flow in this regard (I get the feeling he might be a Darktable/RawTherapee kinda guy and therefore he can't completely fully advise this idiot LR/PS user). Anyway here's his page;
ShinyPhotoScotland | Flickr I don't think he hangs out here?, but his work is of a high standard if you ask me, I get the feeling he knows what he's talking about (super pentax nerd
) heh.
I have never had much success with handheld bracketing/hdr. Really I am hoping that slight bumps in exposure (0.3) will help salvage more from the scene, whilst also carrying off that non 'hdr' look (due to the opacity layer thing rather than how a typical hdr merge shot would present, which I am not overly fond of. I tend to use ETTR principles when doing landscape work and protect the cloud highlights etc...). I aim to test this out over the weekend, heading to some more lovely Autumn gardens, I shall take my 5 bracketed shots and convert them twice, once to a regular hdr shot (perhaps processed in either LR's stock hdr merge or that Nik Collection thing) and once with a Super Resolution process, see which one comes out looking the winner. Because I really like the idea of being able to walk around without the tripod and grab HDR 'pixel shifted' shots
I realise I am trying to run before I can walk here, but I just like to get the answers first before wasting time and shots on edits where a simply tweak here or there could actually produce a much better end version. So with HDR bracketed layers, the bottom needs to be the 'correct' exposure, do you think it matters much where the other layers may lie? Because it's a K-1 I'm thinking the brightest shot as the top layer (weakest opacity), I always find shadows easy to salvage on the K-1. If the final version of the HDR tiff file looks quite dark I'm thinking that's probably a better start to the editing process than the other way around?
Perhaps an order like this;
+ 0.7 (20%)
+ 0.3 (25%)
- 0.3 (33%)
- 0.7 (50%)
0 (100%)
How does that look in theory?
In future, whilst standing there and taken the bracketed shot, without reframing I may try hitting the +/- ev button, turning the dial a notch and firing off a second round of bracketed shots at a different exposure and also combine these to the stack to create a 10 layer (tho that will take practice I am sure to keep the hand pretty steady on the scene and not deviate much, far more advanced and will leave awhile before attempting those, but the thought had crossed my mind).
Thanks again for the informative and detailed reply. I hope to give you some 'physical' results over the weekend.
Originally posted by LensBeginner I can't really edit a 20-layer stack / 20-images smart object, so as soon as I'm done, I flatten the whole thing. I still have the originale though.
Import in series to smart object with auto-align / Average is the way to go for me, saves a whole lot of time, instead of having to open every single file, select all, auto-align, and set the opacity of 19 layers.
YMMV, but I couldn't do it any other way.
I'm not sure I understand much of what your wrote here
