Originally posted by jcdoss Bruce, what's your opinion now that you've got some more experience under your belt on the general utility of Pixel Shift vs Photoshop stacking? Do you have a bottom line summary in a few words?
In general, SR (Super Resolution/Photoshop stacking) is a great alternative to those without DPS (Dynamic Pixel Shift, ie non K-1ii users). It's also a great option to providing a sharper image if you are out without a tripod.
However, should you be out and about with a tripod then tripod with pixelshift, because creating and editing SR images in Photoshop does take a lot of computing power and my machine kinda 'hangs' through some of those processes. Regular Pixel Shifting with a tripod is just quick, and even when I take the RAW file to RawTherapee (for motion correction, I never have motion correction on in camera) it takes a few seconds to process that, then it's off to LR for the real editing.
Originally posted by jcdoss It looks like the stacking solution is working out well, so do you still use Pixel Shift? If so, when would you opt for one over the other?
I pelt you with questions as I've spent time fiddling with dynamic Pixel Shift and have so far been underwhelmed.
I have also been using Pixel Shift a fair amount recently with certain lenses to do stuff like 'Aperture Stacking'. Below are some example images;
The areas that are sharp in these images have been taken (with pixel shift) at more stopped down apertures, the softer out of focus areas been shot wider open (sometimes with pixel shift sometimes not needed). The shot is actually taken quite quickly in Av mode, and I tend to adjust the aperture ring only and use a remote to take the shot. I also shoot waterfalls and combine a longer exposure frame (no pixelshift) with an additional pixelshifted shot for boosting sharpness on static non moving parts (rocks, trees etc). Like below;
(rocks pixelshifted, flowing water is not).
You can't do this easily handheld and using SR technique...
Whichever method you choose I find creating a User Mode helpful and assists with streamlining the whole process. I have one User Mode set up for pixelshifting (ie it's turned on) and have such things as firing from the wireless remote preconfigured. I even set out with my K-1 already docked in a small tripod, wireless remote in pocket it all helps to just take quick pixelshifted shots. Most of these recent wet garden shots were all tripodded with pixelshift;
Rustlings Garden | Flickr
It's also handy to have a SR User Mode set up, and I prefer a bracketing approach to creating those shots, something that gives me a little more dynamic range to work with than 5 burst shots of the same exposure (besides I'm not seeing real benefits from pushing past 4-5 frames, and the additional computing power and waiting time past 5 frames makes me feel it's not worth it).
As always it depends on the methods you're employing and the situation you're in. I probably prefer pixel shift as from start to finish it's just less painful, however it does mean you need a tripod, even a small one. There are times I want to shoot handheld only and have had enough of tripods and so SR shots are handy. I go between both methods.
