Ok, so I'm not sure where to put this subject matter in terms of category so I've chosen 'Action' as in terms of difficult, quick or impromptu shooting rather than any other scenario.
On the weekend I took an image at ISO 800 that I felt was very sharp and clean, please see below;
I was in Av mode, and this was a total impromptu shot, the f5 aperture was left over from shooting someone else in a different location/scene, but you can see I had a shutter speed of just 1/40th, and with kids that's dangerously low, basically I got lucky here.
But it made me think... I was really impressed with the image quality at ISO 800, am I 'damaging' my potential success shot rate by insisting on getting those images captured at the 100-400 ISO level, when really ISO 400-1600 is perfectly acceptable? I think I have been put off with 1600-3200 ISO in the past as that's usually what I get when shooting concerts and public speakers, but I feel as though the noise of ISO changes its impact depending upon what is being photographed (such as closeness of the subject etc, further away the grain/noise feels more pronounced, closer in (like above) and it comes off as almost completely clean).
I have been exploring Av Mode recently. Currently I have it bound to 3 User Modes, each mode is the exact same settings wise except in the Menu 1>ISO Auto Setting>AUTO ISO Parameters is set to Slow (User Mode 1), Normal (User Mode 2) or Fast (User Mode 3). If you're unaware of what this does, it changes the minimum shutter speed encountered before bumping up the ISO, the shutter speed only drops further if/when encountering the need for correct exposure past the (Maximum) ISO Range set.
So if the subject is relatively still (or posing), I have been tending to use User Mode 1 (Av) and AUTO ISO set to Slow, if the subjects are little people that fidget and move a lot more then I toggle to User Mode 3 (av) where AUTO ISO Parameters are set to Fast.
Example;
K-1+DFA 100, ISO Parameter Slow = 1/60th shutter speed. If I set my Max ISO to 3200 then once it hits that limit the shutter speed will drop below 1/60. When ISO Parameter is set to Fast shutter speed will not drop below 1/250th.
Interestingly enough the KP takes this process one step further and allows you to actually specify the exact shutter speed met, rather than with a general 'Slow', 'Normal' and 'Fast'. Neat.
So... having taken this shot on the weekend I am starting to evaluate my necessity in having those shots taken at very low ISO's such as 100 and 200 etc. I can set the Minimum ISO Range as well as Maximum. Perhaps if I chose a minimum of 400 or 800 I would obtain more shots with higher shutter speeds, rather than letting the shutter speed get down so low as to keep the ISO at 100 etc. It's kinda another way of approaching how Av mode works, Slow, Normal and Fast or just play with the Min ISO more.
I created these 3 Av User Modes with variable AUTO ISO Parameters because changing them requires a bit of menu diving which is a PIA, however I have noticed that you can press the INFO button during shooting which takes you to that handy quick selection shortcut whereby you can't have AUTO ISO Parameters for quick selection change, but you can however have ISO AUTO MIN and MAX for quick on the fly adjustment!
It wasn't my intention to always have 3 of my User Modes bound to Av mode with only a slight deviation between them, it was just a trialling process, but the idea of having one Av mode whereby you can make quick ISO AUTO MIN adjustments appears to me to be a decent streamlined compromise.
My real purpose of this thread is to see if anyone else has felt similar, that ISO 100 is unnecessarily clean for certain situations (like overkill basically) but by having it there (even in an Auto ISO situation) has harmed the outcome of certain shots because motion blur or being scared to bump the aperture up slightly (at the expense of shutter speed) ruined the shot?
Of course I understand that ISO 100 is necessary for lots of situations such as landscape work etc, pixel shift and super resolution bla bla, which is why I dumped this question/point into the 'Action' category.
Thoughts people?
Cheers,
Bruce
