Hi all;
In normal orientation, a DSLR lens is going to project an image circle of either full frame size or APS-C size on a sensor at the registration distance, depending on the format for which the lens is designed. If it is reversed for macro work, is the resultant image circle now going to be determined by the focal length of the particular lens, rather than its intended format? Will a reversed wide angle lens thus have a larger image circle at the sensor plane than a reversed normal lens? Just wondering this because of the possibilities of macro tilt/shift applications using reversed w/a optics. I know that for DIY T/S rigs larger format lenses are recommended because of the longer registration distance and the larger image circle. For macro work, the former is not be an issue because infinity focus isn't needed, but the latter is still going to be necessary to accommodate the desired lens movement.It would be nice to have more control over placement of the plane of focus in macro shooting. Whether this practical for my preferred hand held way of working might be another matter...
Not that I'm anywhere near doing tilt/shift macro stuff, but it might be good to know for future reference. It might also inspire me to put something together sooner than I would otherwise.
