08-09-2018, 06:21 PM   #16
GUB
GUB's Avatar
Time to have a bit of a test. My question still is electronic shutter vs Mechanical shutter.
I set up on a tripod for constancy but with a monopod in mind.
My tripod is a medium weight one and I left the quick attach a little loose so the camera could flail around a little on its own hopefully to exaggerate shutter shake.
The top 2 rows are with the shutter set to 12 second delay and SR off by default.
The bottom 2 rows I fired the shutter as usual with my finger as you would with a monopod.
So SR was on here.
I feel the results vindicate the view that shutter shake is limited to the 1/60 to 1/200 area.
The stand out shot though has to be the hand fired 1/50 mechanical shutter SR=on. The fact that it is better than the 1/100 next door is a good example of SR being a little hit or miss.
My own conclusion here is that a little trust (and hope) in SR outweighs going overboard with Iso.
So the biggest pity I feel with my Falcon shot is that I had the camera on Electronic Shutter.
The Magnolia flower stamen crops are 300 pixels crops from the centre of the image. I had to downsize about 50% to upload the test to here. I used the 400-600 mirror @600mm on the K-1. I did not change focus through the test. Images saved as jpg camera default.
08-10-2018, 06:12 AM   #17
Was this with live view on or off? With live view off you will also have mirror slap, not only shutter shake.
08-10-2018, 08:11 AM   #18
It's great that you've done the test.
There are a couple of additional things to consider. First, SR isn't intended for tripods, even slightly wobbly ones. So I'm not surprised that you got some inconsistent results. Second, if you typically will use the monopod for these shots then perhaps you'd benefit from repeating the test with a monopod (electronic, mechanical, mechanical + SR) . Third, since birds can move, relying on slow shutter speeds might get you a sharp background with a blurry bird. Better to use something like 1/500 or faster, if possible.
08-10-2018, 12:27 PM   #19
GUB
GUB's Avatar
QuoteOriginally posted by Gimbal Quote
Live view on - the only way to focus a long lens like this.
08-10-2018, 12:38 PM   #20
GUB
GUB's Avatar
Trouble with using a mono-pod for the test is to get consistent focus and not bumping the focus while you are handling it.. The Dof calculator for this situation says dof of 140mm for FF 600mm 8 metrs f12 - personally I more than halve the results from the old standard coc. - so you are thinking a dof here of say 50mm. which means it is very easy to sway in or out of it with a mono-pod.
Good point about subject movement. I was thinking the optimum with the above lighting was third row down 1/400 sec Iso 800. Trouble is the Falcon was at least 4 stops dimmer so I suspect optimum would be a stop slower and a couple of stops extra on Iso.
08-10-2018, 01:13 PM   #21
clackers's Avatar
QuoteOriginally posted by GUB Quote
08-10-2018, 05:23 PM   #22
GUB
GUB's Avatar
08-22-2018, 07:11 PM   #23
Higher shutter speeds help a lot, but electronic shutter is not always better. When the subject moves I find that a mechanical shutter is best.
08-23-2018, 01:38 PM   #24
GUB
GUB's Avatar
QuoteOriginally posted by beakhammer Quote
After doing that test, for me, electronic shutter is now only for tripod work where SR is off.
08-25-2018, 07:24 PM - 1 Like   #25
makes sense.
08-18-2019, 08:46 PM   #26
Lmcfarrin's Avatar
As of current technology manual shutter produces better resolved images.
camera, course, image, iso, k1, photography, post, shutter, stabilization, technique
Rolling shutter effect when using electronic shutter D1N0 Pentax K-1 10 07-27-2018 02:37 PM
Does the electronic shutter provide anything other than ultrafast shutter speeds? jake14mw Pentax KP 19 06-21-2017 04:34 AM
On K1 - Mechanical VS Electronic shutter question! Fenwoodian Pentax K-1 5 10-21-2016 03:27 PM
K1 pixel shift and electronic shutter biz-engineer Pentax K-1 9 06-01-2016 09:46 AM
K1 menu - electronic shutter 2351HD Pentax K-1 6 05-05-2016 08:57 AM
All times are GMT -7. The time now is 02:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
