A normal exposure of the sun shouldn't be a problem, but I wouldn't use live view extensively with the sun in the picture, especially with tele lenses, that goes for your eyes too (don't search for the right camera settings while looking into the sun, just compose and take the picture you can check your exposure on the resulting picture on the camera display)
edit: as Mark said, don't look directly into the sun when it is in the frame, look at the hills, trees, clouds or whatever else is in the frame. The longer the lens gets, the higher is the risk of damaging eyes or camera because the sun takes a bigger proportion of the image. With a 400mm lens I felt comfortable enough to photograph some leaves on a tree with the sundown behind the leaves, with a 1000mm lens I would rather risk my camera than my eyes and use live view to compose the image
