08-11-2018, 10:32 AM   #1
Question on Evening-Light Teckni Queue.
I'll be taking some photographs of my niece (singer) and her jazz band tonight. Supposed to be a clear evening - starts between 6:30 and 7. Sunset here (EST, US) is about 8:50 today. The porch where they play is backed up by the cafe where they are, and they will be facing south.
My plan is to use a zoom lens of some sort - I have a Tamron SP 35-210, along with carrying my 50mm plastic fantastic, just because. I also have a flash - TT560.
Any recommendations, generally, or thoughts?
08-11-2018, 12:10 PM   #2
If it were me I would shoot tav mode set your aperture and shutter to what you want and let the iso adjust to what it needs.Take care of the noise in post. I have only used my flash a couple of times. So I can’t make any suggestions.
08-11-2018, 01:05 PM   #3
UncleVanya's Avatar
Don't use flash unless you plan to take some headshots ahead of the gig and need it for fill light.
08-11-2018, 01:10 PM   #4
Perfect, Uncle Vanya. Thank you for the advice.
08-11-2018, 01:24 PM   #5
UncleVanya's Avatar
This shot was made in a dimly lighted converted church. It was for a Folk Society concert.
The shot was made with a Panasonic GX-1 (16mp older m43 sensor) that isn't great at low light. I did this shot with the 45-175 Panasonic f/4-5.6 lens.
There are a few more including some B&W shots made the same night.
08-11-2018, 01:30 PM   #6
What settings on the shot?
08-11-2018, 01:39 PM   #7
UncleVanya's Avatar
QuoteOriginally posted by jawats Quote
If you click it you can get most of the EXIF from Flickr but here's what I can recall:
Shot in Av mode (my default) with ISO 3200 - Wide open (f/5.6) and 1/25s. White balance was set to Tungsten but I shot in RAW+JPG and processed this from RAW. DXO Prime noise reduction applied. It is a little soft due to movement. You can see how sharp some non-moving parts are so the image stabilization was hitting on all cylinders (175mm / 350 effective on FF field of view, just about 3-4 stops of image stabilization likely). All shots hand held. For this one I may have rested my elbows on the seats in front of me that were empty.
08-11-2018, 01:45 PM   #8
In my K-3, I think I can shoot in auto mode, but bracket the ISO to between 100 and 3200. The Tamron is 3.5 - 4.2. Would you recommend taking my 50-200 DAL ED WR, instead of the Tamron? The Tamron is a bit wider, but the AF in the evening light might be better.
08-11-2018, 01:56 PM - 1 Like   #9
UncleVanya's Avatar
I don't really know that Tamron I'm afraid. The venue I was in was small and I had a good seat but not super close. I'm linking a shot below that isn't fantastic to show roughly what the view was from the seat. This was shot with a Panasonic 20mm (40mm FF field of view). The 175mm I was toting is about the same as using a 280mm on crop in terms of field of view. I regularly shoot a K-3 and would happily have shot this with my DA* 60-250 f/4 but wasn't sure how much room for gear I would have in my seat. The DA 50-200 is an odd lens. I had one and enjoyed it but it has a reputation for being soft. The 30mm Sigma (60mm FF, 48mm crop) was my most shot lens but I did end up preferring the 45-175 shots the most. The 20mm (40mm FF, 32mm crop was too wide from where I sat). It really will come down to where you can sit and your lighting will likely be better at least while the sun is out than mine.
08-11-2018, 02:02 PM   #10
Thank you for all the advice, U.V.!
08-11-2018, 02:43 PM - 1 Like   #11
UncleVanya's Avatar
Your welcome. I occasionally shoot bands for my own enjoyment, but I'm not the expert. If I had to do it more often I'd get a k-1 and the DFA 70-200 or I would use a KP and the DA* 50-135 and get closer.
08-12-2018, 07:26 AM   #12
UV - here are a few of the shots I got - used the 50-200 and natural light. Some pp in LR. Thanks again for the rec's!
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
08-12-2018, 08:41 AM - 1 Like   #13
UncleVanya's Avatar
The last one is particularly good. I'm glad you were able to make this work. The 50-200 gets a bad rap, I think I have read that the long end suffers on longer shots more than midrange shots but I can't recall if I really felt that way. I got mine as part of my original purchase (used) of a K100d Super and a 2 lens kit (18-55 mk1 & 50-200). I have since sold the lenses but I kept the K100D Super, it's my backup lens conversion body.
08-12-2018, 04:42 PM   #14
Thank you - I appreciate it. The venue was much smaller than I expected, so I think I would have taken the 16-45 if I had known. I should have taken it with the bag, regardless. However, the 50mm end of that lens worked fine. It may get a bad rap because it's a kit lens, but for a relatively inexpensive 50-200 zoom, I'm pretty pleased with it. Plus, with Lightroom or Photoshop, I think one can correct a great deal of non-focus issues.
camera, evening-light teckni, photography, question on evening-light, technique
Abstract From A Nation That Needs To Queue... Kerrowdown Post Your Photos! 8 01-24-2018 03:42 PM
A Queue of Q's BigRed Pentax Q 5 11-06-2016 09:33 PM
PPL / DCU 4 question: queue blende8 Digital Processing, Software, and Printing 2 01-03-2010 02:35 AM
All times are GMT -7. The time now is 07:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
