Originally posted by slartibartfast01 Doesn't the sensor position reset after each shot using astrotracer?
The sensor position doesn't reset during between pixel shift frames. On my K1, it works the following way:
- sensor tracks star motion
- 1st ps frame is exposed
- sensor shifts 1 pixel from last sensor position
- sensor continues to track star motion from last position
- 2nd ps frame is exposed
- 3rd ps frame is exposed
- 4th ps frame is exposed
- sensor position resets
- mechanical shutter closes
- black frame exposure (if low shutter speed NR is enabled or auto with exposure longer than 1 second).
So I effectively get full RGB definition of seemingly fixed stars. If there is a foreground, if it only selected from a single frame if motion correction is enabled, if motion correction is disabled then the foreground will have lots of pixel shift artifacts since the sensor was not at the same position for each of the 4 pixel shifted frame.
