10-15-2018, 12:29 PM   #1
Identifying a couple of odd filter discs
I'm trying to sort out a lot of old filters and there are two that have me a bit baffled. They're glass discs without holders, I'd guess intended for 62mm filter mount, and both are very thick and very dark - I put one in front of a camera pointed at a bright light, the meter reading went from 1/320th f5.6 to 1/6th f5.6, e.g. 6 stops (ish). One has a slightly grey/brown tint, the other is blue, both seem to cut down light by roughly the same amount.
Anyone got any idea what they might be for?
10-15-2018, 12:51 PM   #2
Unregistered User
Guest
Lenses for welding goggles?
10-15-2018, 01:15 PM   #3
Alex645's Avatar
QuoteOriginally posted by Marcus Rowland Quote
If you posted a photo, it would help. If it wasn't so large, it could be for a rear mount mirror reflex telephoto or for a telescope (moon viewing, not the sun), but at 62mm and without a ring, it's hard to say. For a spot light, they would use gels, as the glass could easily break from heat. Where did this come from?
10-15-2018, 01:32 PM   #4
photoptimist's Avatar
Might they be IR-pass (visible-block) and UV-pass (visible-block) filters? Those would be useful for pictures with a camera with a full spectrum conversion.
(P.S. If you are measuring the attenuation of very dark filters, make sure you cover the eyepeice to get an accurate reading.)
10-15-2018, 02:20 PM   #5
The trouble with taking a photo is that they look pretty much like black disks - I could take a picture through them, I suppose, I'll try it in daylight tomorrow. Maybe the light curve would tell me something.
I wouldn't have thought they were cutting out part of the spectrum completely - if I look at e.g. a computer screen it looks like some light is coming through across the visible spectrum. It's more like one is like an old-style A to D filter and the other D to A, but with a huge reduction in light level.
10-16-2018, 12:32 PM   #6
Here are some photos:
The two disks together
Holding them up to the light
Effect when used as a filter (no filter, then blue, then greyish-brown)
Unfortunately I forgot to switch off auto ISO setting. Exposures are 1/160th f9 at ISO 100 for the one without a filter, 1/40th f5.6 at ISO 400 for the blue filter, 1/20th f5.6 at ISO 400 for the grey one
If I'm working this out correctly it looks like approximately a 7-8 stop decrease plus colour changes for each of the filters. I'd say the last one looks warmer than unfiltered daylight.
10-19-2018, 12:51 PM   #7
TaoMaas's Avatar
QuoteOriginally posted by Cipher Quote
That was my first thought, too, when I read this the other day. I would think that if they were intended for use in photography, they would have some means of attaching them to a lens. Maybe there's some kind of holder for them that's missing or they're drop-in type filters for some specific lens or telescope.
10-21-2018, 09:04 AM   #8
OK, if the general consensus is goggles I'll leave it at that, and keep them in case I ever need an extreme ND filter for some reason.
camera, discs, f5.6, filter, light, photography, technique
Soft Focus Discs as Filters K David General Photography 5 11-25-2018 12:02 PM
Identifying Pentax 67, 6x7 105 f/2.4 Lens versions rich14 Pentax Medium Format 3 09-17-2017 04:37 PM
Pentax K20D Started Discs P Shooter Troubleshooting and Beginner Help 4 07-16-2013 04:52 PM
A couple of odd photos scott-devon Post Your Photos! 6 08-30-2009 01:50 PM
A couple of odd pics from yesterday wjwncpro Post Your Photos! 3 03-29-2007 11:40 PM
All times are GMT -7. The time now is 08:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
