04-10-2019, 04:28 PM   #16
QuoteOriginally posted by BruceBanner Quote
That helps heaps. I must have fluked things enough with the blending in pp between the two exposures. I went 1/8 to 1/32 and chimped the shots and they looked about the same in brightness so thought I got that right, but then the velvet glow at f2 does make things hard to judge, not just sharpness but brightness/exposure as well perhaps :S
I'll retest today. I love the '3 clicks per stop' and I can run with that.
What about the EV difference flash calculator stuff, I might not always have charts with me for reference etc. Is there any simple maths I can do in my head to find the EV difference? Like.. I know it would get complicated to add in a 2nd and 3rd variable (shutter speed variance and ISO change) but let's for arguments sake pretend that I will only be shifting aperture in this regard, how can I easily figure out of f5.6 >f2.8 is xEV difference, f8>f2.8 etc etc?
You need to memorize the full aperture f stop sequence. It's not hard == 1, 1.4, 2, 2.8, 4, 5.6, 8, 11, 16, 22, 32. Each of these values is one stop difference. If your camera is set to 1/3 stop increments, you can simply set one f stop there and then count the clicks until you reach the one you want.
04-11-2019, 03:05 PM   #17
BruceBanner's Avatar
QuoteOriginally posted by West Penn Quote
And so with a lens like the lensbaby where it doesn't do f1.4 but f1.6 I should just pretty much round it to the nearest and treat it like f1.4? It would be such a small difference in exposure anyway right?
04-11-2019, 04:50 PM   #18
photoptimist's Avatar
You want the base-2 logarithm of the square of the ratio of the f-stops. Easy, peasy!
The square of the ratio of two f-stops gives the ratio of the light levels:
((F-Stop1)/(F-Stop2))^2
For f8>f2.8, thats (8/2.8)^2 = 8.2.
The change in EV is the base-2 logarithm of that ratio
log2(8.2) = 3 EV
Or you could just count clicks of the e-dial.
04-12-2019, 12:20 AM   #19
log2(8.2) = 3 EV
What part of 'I failed school miserably' did you not follow
I don't even know how to do the ^2 part of the sum on a calculator... there's no hope for me...
04-12-2019, 05:33 AM   #20
F/1.6 is 1/3 of a stop smaller than f/1.4, so you're right, you probable wouldn't notice the difference. Or, give it one less click or one more click on the speedlight dial depending on whether you're closing or opening the aperture.
aperture, background, backgrounds, box, camera, clicks, count, ev, f/2, f1.8, f8, flash, iso, lens, lensbaby, lenses, light, mode, photography, post, power, shot, shots, speedlight, technique
Lens potential comparison calculator beholder3 Photography Articles 10 05-18-2012 06:44 AM
optimum hood depth calculator? rparmar Pentax SLR Lens Discussion 77 03-06-2011 02:13 PM
Macro Extension Tube Calculator Ouroboros Photographic Technique 10 12-04-2010 12:53 PM
Blackberry Depth of Field Calculator! elcahall Pentax DSLR Discussion 9 12-11-2009 11:05 AM
DOF and FOV calculator MoiVous Pentax SLR Lens Discussion 2 05-31-2009 10:52 PM
All times are GMT -7. The time now is 03:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
