06-11-2019, 09:05 AM   #31
You are completely ignoring the effect of the overlap of the circles of confusion.
I guess downsizing might work the same way and looking at a print from further away, so when the blur is close to pin sharp it's not visible, but it become visible as soon as the blur of defocus become significant relative to pixels, same with diffraction.
There is also the relative sharpness in the frame. If I use my Samyang 85 1.4 wide open focused on a portrait, the person's face look sharp relative the blurred background. But in the center the Samyang 85 1.4 is not even as sharp as a Pentax 18-55 kit lens wide open. The perception of sharpness is relative: if you missed focus on the bird's eye, but other parts of the image like feather are sharp, no matter how much you downsize the image the bird's eye will never look sharp because there is an area next to it that's sharper.
06-11-2019, 11:20 AM   #32
With modern magic maybe some details can come back.
06-12-2019, 05:48 AM   #33
normhead's Avatar
It doesn't matter what you do it will never be this.
You tend to be OK with the top one unless you already have lots of images with the bottom one. I almost didn't post the top one, it was kind of a whim.
06-12-2019, 05:56 AM   #34
Did you notice that I recovered details on your image?
06-12-2019, 06:09 AM   #35
normhead's Avatar
Ya, impressive. Don't make me smack you upside the head.
06-13-2019, 04:12 AM   #36
It rarely is a case for landscapes. You stop the lens down to f/64, and eventually get circles of confusion confused with airy disks at the center, everything would become equally soft.
06-13-2019, 05:49 AM   #37
normhead's Avatar
Where the diffraction point is depends in part of how big the lens is. ƒ64 is necessary only on very large format cameras. Long lenses that are big.
Worth noting that angular resolution and DOF/defocus is related to absolute aperture size, not f-number, so you can also just plug in the values for "f" to compare.
The iPhone 6 has f=4.15mm, a lens with similar FOV on an 8x10 has f=200mm.
200mm / 64 = 3.1mm -> the size of an f/64 aperture on a 200mm lens.
4.15mm / 2.2 = 1.9mm -> the size of on f/2.2 aperture on the iPhone 6.
Although the 8x10 will often have less defocus due to movements (photographer control of focal plane).
Group f/64 | Hacker News
Diffraction is caused by the size of the hole for the aperture, not the ƒstop per se. The size of that hole gets larger as the focal length of the lens gets longer. And the lager the format, the longer the focal length of the "standard" lens.
06-13-2019, 05:56 AM   #38
Diffraction is caused by the size of the hoel for the aperture, not the ƒstop our se.
Yes. Good to remind that.
06-14-2019, 03:19 AM   #39
Of course not. No matter how practical you example can be, my landscapes don't look like a yellow bird .
As you know there is a theoretical practice and practical theory, they are two different kind of animals
aperture, camera, cameras, coc, depth, distance, distances, dof, focus, focus distance, frame, ft, landscape, length, pentax, photography, plane, post, resolution, rule, scene, sharpness, technique, videos, youtube
New to photography - looking for advices on the Pentax system Tanguy Troubleshooting and Beginner Help 59 08-28-2018 12:55 AM
K1 setting for landscape and hyperfocal biz-engineer Pentax K-1 32 08-07-2018 10:17 AM
Nature Wrong Lens, Wrong time, Wrong…………. lukulele Post Your Photos! 4 05-08-2014 03:11 AM
Confirm my understand of metering w/ manual lenses focus hyperfocal focus DeadJohn Pentax SLR Lens Discussion 4 03-25-2011 12:31 PM
Understanding Hyperfocal Focus nandystam Troubleshooting and Beginner Help 9 02-09-2011 09:43 AM
All times are GMT -7. The time now is 09:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
