Originally posted by bluestringer I'm assuming the working distance stays the same with just the 2x converter attached, correct? I know it changes if I use a extension tube.
Correct. The distance from the front of the lens to the subject does not change when adding a teleconvertor. The front lens stays put, the teleconvertor gets added to the back, and the camera goes on the back of that. Obviously, that does mean moving the tripod or yourself back by a distance equal to the thickness of the teleconvertor. You'll get 2:1 magnification with the convertor with the same working distance as 1:1 mag had without the 2X.
Or you can use the teleconvertor to get 1:1 with a longer working distance -- just set the lens to 1:2 (half of 1:1) and then add the teleconvertor.
