Show Printable Version 27 Likes Search this Thread
07-18-2019, 05:16 AM   #1
Photographying in summer with polarizer or sunglasses?
It is mid summer here in Europe, very sunny days, early sunrises and late sunsets, also a period of the year when a lot of people become tourist traveling to nice sight seeing destinations (you see what I mean...).
Lots of sun is nice, set your camera to 100 ISO, unfortunately daylight shots don't look good, intense highlight, black shadows, with atmospheric haze on top.
You will say: "it's easy, just screw a polar filter on your lens".
Using a CPL means:
- losing 1 stop of light (Ok, if there is plenty of sun)
- having to rotate and double guess what the right amount of rotation should be
- getting a little less haze, a little more saturation, not a huge improvement
- and, non uniform effect with a wide angle / wide field of view
On the contrary, I'm impressed by what I see with my sun glasses, the pictures taken by the camera even with using a CPL are never as good as what I see with sunglasses, often lead to being disappointing by the photographs compared to what I saw when wearing sunglasses. So does anyone know what the difference of secret recipe between sun glasses and photographic polar filters sold? Should I bring my Pentax K1 to the eye doctor and ask for a special summer monocular prescription?
07-18-2019, 05:50 AM - 4 Likes   #2
photoptimist's Avatar
It depends on the sunglasses but many seem to include some color filtration that removes shorter wavelengths light common in haze and that give the lens a brownish tint.
If your sunglasses are prescription glasses, you might well be able to find a friendly optician who could order an uncut 0-diopter lens made with your sunglass's materials and coatings. I think they are available in diameters of 50mm and maybe 70mm.
P.S. Step 1 might be to try to shoot a picture through your sunglasses to see if they really help. The difference between the CPL and your sunglasses could be the difference between a silicon CMOS sensor and a carbon-based retina sensor.
07-18-2019, 05:58 AM   #3
Dartmoor Dave's Avatar
It's the same for me: I much prefer the way things look through my sunglasses, and I've never found a photographic polariser that works as well. I think I did get better results with linear polarisers back in my film days than I do with modern circular polarisers on a DSLR, but that might be more because of the differences between film and digital sensors than because of the polarisers themselves.
07-18-2019, 06:14 AM - 3 Likes   #4
QuoteOriginally posted by Dartmoor Dave Quote
Polarizers vary in quality. Cheaper ones have poor polarization performance in shorter wavelengths (the opposite of what is needed for cutting haze.)
If you stack two polarizers (Note: if the front one is a CPL, it will have to be reversed) and rotate one, the scene should go pitch black. If either polarizer is of low quality, the scene might just become dark blue or purple.
Also, some TVs, laptops, and LCD screens have extreme good polarizers in them (which are required to get the blackest blacks). You can test your polarizers by looking at the screen through the filter, and rotating it. If the polarizer is high-quality (screen goes black) or low quality (screen goes blue/purple/muddy gray). If the view of the screen doesn't change much, then the screen either doesn't use LCD or it has a quarterwave plate on it.
07-18-2019, 06:23 AM - 2 Likes   #5
I suspect some (a lot? most?) of this is a psychological effect.
When viewing with your eyes in real time, there is a lot of processing going on in your brain, because you "know" what things should look like. So, the variation in intensity across your field of view due to polarization effects get compensated for.
Whereas, your camera records (more or less) exactly what the light intensity is across the FoV.
Try comparing wide angle views/shots (where the polarization is likely to be variable*) with narrower FoV views/shots.
Are your sunglasses polarized? If, as photoptimist suggests, they are in reality mostly tinted/absorbing (of UV rays in particular - which are what contribute most to the scattered light due to haze), they do not cause any effects due to polarization, and hence won't see the scenery as does your camera with polarizer.
*Polarization of scatted sunlight depends on the angle of view with respect to the position of the sun. The polarization effect is most pronounced (highest fraction of the scattered light is polarized) for light coming to you at an angle of 90 degrees from the sun. If the sun was exactly straight overhead, polarization would be maximum along the horizon - and a photograph with a polarizer might look almost "normal." If the sun is rather low in the sky (conditions for early morning and late afternoon - especially at higher European latitudes), and you are shooting with a wide angle lens in a direction at ~45 degrees from the sun, there will be significant variation in the intensity of the polarized light across the FoV - maximum near the edge away from the sun and minimum on the edge near the sun - the effect being biggest if your FoV happens to be around 90 degrees.
CPL versus linear makes no difference - that has to do only with how the filter achieves polarization filtration and passes the light on to the sensor - not the effect of the impinging polarized light.
07-18-2019, 06:38 AM - 4 Likes   #6
The human visual system (eyes plus brain) should be getting more credit than the sunglasses get.
Our vision is wide angle but we only concentrate on a small part of the field. As you shift concentration between bright and dark features your vision reflexively reconfigures itself. We have 20+ stops of dynamic range. We aren't limited by a viewing screen or printer.
Cameras vs. The Human Eye
07-18-2019, 06:45 AM - 2 Likes   #7
pete-tarmigan's Avatar
I just rotate until I achieve maximum contrast between the clouds and the clear blue sky, or when the green of the vegetation achieves maximum colour saturation. I don't use a polarizing filter on overcast days.
07-18-2019, 06:49 AM - 2 Likes   #8
Seeker of Knowledge
aslyfox's Avatar
" there's [ an article ] for that "
Polarizing Filter Basics - Articles and Tips | PentaxForums.com
well, it talks about polarizing filters at least
07-18-2019, 08:20 AM - 3 Likes   #9
Otis Memorial Pentaxian
The difference is the additional tint (usually minus blue) with the sunglasses plus the superb detector in the back of and behind your eyes.
07-18-2019, 09:25 AM   #10
I have an old pair of sunglasses made to correct vision, has polarizing filter layer + color filter (more like green/yellow) and it give the visual impression of lots of contrast, colorful without haze. I have seen ND filters, ND grad filters, CPL filters, and B&W color filters for photography, but never seen any filter optimized for photography in harsh summer light.
---------- Post added 18-07-19 at 18:27 ----------
Ah ah, I've tried step 1 already (with old glasses) but those glasses aren't flat, and they are too small to cover the front of the lens, not an easy task.
---------- Post added 18-07-19 at 18:32 ----------
QuoteOriginally posted by AstroDave Quote
Yes, that's what I see in the skies with a CPL on the camera on a wide angle lens. I suppose my two eyes behind the sunglasses are also wide angle but I do not seen a the blue sky fading on the corners like it is with the camera.
07-18-2019, 10:27 AM - 1 Like   #11
I have never seen an optical filter that produces post card color intensity. I am happy that I have never seen one.
Use PL, play in Lightroom...
07-20-2019, 12:15 AM   #12
QuoteOriginally posted by zapp Quote
Thanks for pointing that out. It's perhaps that sunglasses set unnatural expectations for how the scenes looked like, from memory.
07-20-2019, 01:28 AM - 2 Likes   #13
Sandy Hancock's Avatar
The difference is the superb detector in the back of and behind your eyes.
YES.
Our brain sees what it wants to see. The camera sensor sees what is actually there.
10-10-2019, 04:31 AM   #14
Yes, I've often wondered why they don't do polarizing filter working as the glasses ones : they work consistently whatever the angle to the sun !
10-10-2019, 04:33 AM - 1 Like   #15
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by agukha Quote
. . . they work consistently whatever the angle to the sun !
easily confused
and admittedly not knowledgable
but I think that is impossible at least regarding the polarizing effect ?
Polarized Sunglasses
Polarizing sunglasses cut road glare better in some positions than in others.
When light reflects from water, asphalt, or other nonmetallic surfaces, it becomes polarized—that is, the reflected light is usually vibrating more in one direction than others. Polarizing sunglasses reduce this reflection, known as glare, but only when the polarizing lenses are oriented properly.
https://www.exploratorium.edu/snacks/polarized-sunglasses
Most of the glare that causes you to wear sunglasses comes from horizontal surfaces, such as water or a highway. When light strikes a surface, the reflected waves are polarized to match the angle of that surface. So, a highly reflective horizontal surface, such as a lake, will produce a lot of horizontally polarized light. Therefore, the polarized lenses in sunglasses are fixed at an angle that only allows vertically polarized light to enter. You can see this for yourself by putting on a pair of polarized sunglasses and looking at a horizontal reflective surface, like the hood of a car. Slowly tilt your head to the right or left. You will notice that the glare off the surface brightens as you adjust the angle of your view.
A lot of sunglasses advertised as polarizing actually are not. There's a simple test you can perform before you buy them to make sure. Find a reflective surface, and hold the glasses so that you are viewing the surface through one of the lenses. Now slowly rotate the glasses to a 90-degree angle, and see if the reflective glare diminishes or increases. If the sunglasses are polarized, you will see a significant diminishing of the glare
https://science.howstuffworks.com/innovation/everyday-innovations/sunglass6.htm
angle, camera, color, cpl, filter, filters, glasses, haze, lens, photography, step, summer, summer with polarizer, sun, sunglasses, technique
adjustable rubber grip for mounting flash and Polarizer filters adsouza Troubleshooting and Beginner Help 4 12-19-2017 03:38 PM
Photographying snow flakes? biz-engineer Photographic Technique 18 01-05-2017 08:08 PM
Summer is upon us... Whats your go to summer kit this year? wanderography General Talk 2 06-10-2012 09:15 PM
Machinery the summer wind waiting for summer.. dcmsox2004 Post Your Photos! 2 04-29-2011 01:57 PM
Summer as summer can be in the Austrian Alps stern Monthly Photo Contests 0 10-10-2009 05:09 PM
All times are GMT -7. The time now is 05:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
