Originally posted by dave2k Since the model is on a platform, height is probably greater than 6 feet.
Reviewing the video, I see you are correct with an estimate of about six foot. I have corrected my comment. OTOH, I actually checked relative size with lens, camera, and tape for 24mm before posting and measure about 9 foot vertical FOV at 10 feet distance. Allowing for the 93% viewfinder coverage, that is pretty close to the 10 foot figure given by the FOV calculator at the linked page below:
Camera Field of View Calculator (FoV)
The model/manikin (pedestal included) occupies a little over 50% of the vertical dimension of the example for 24mm at 10 feet. That is what skewed my estimate of height to about 5 foot. I suspect that the Canon EF 16-35mm f/2.8L III used in the test might shoot a little wider than the nominal focal length. Either that or the photo was taken from further back than shown in the video.
Addendum: I am usually not this compulsive about things. It was just that the 24mm shots appeared far wider than my experience with the focal length.
