Originally posted by biz-engineer For single long exposure (2 to 4 minutes exposures) around sunset (or sunrise) the light level drops (or increases) rapidly, making it difficult to nail exposure base on the automatic exposure time evaluation before the exposure takes place. Using a weak ND filter for a multi-exposure composite average in Av mode, is a method that nails exposure of the total stack because AE metering tracks falling light level before each of the shorter exposures, so in that case the composite average mode has the advantage over a single exposure.
Great point!
I miss the TTL timed-exposure systems of some film cameras that kept the shutter open until they had accumulated enough light in real time after the shutter opened.
That can be emulated with interval composite set to additive mode with the "Save Process" option -- one can pick the image in the set that reached sufficient exposure without blown highlights. Of course, additive mode does accumulate dark current.
One other big advantage of interval composite is that it can show the blurred scene over a long time period without holding the shutter open the entire time and accumulate too much dark current noise. For example, 60 shots taken with a 1/100 shutter speed on a 1 minute interval provides a similar effect as a deep ND shot with a 1 hour shutter time. But the interval composite shot only has 0.6 seconds of open shutter time so the dark current is miniscule.
