Originally posted by biz-engineer In any case, nothing of that is a solution to avoiding the range of shutter speed between 1/20th s. and 1/180th s. except doing it manually in M mode or TAv modes. For me the Sony 47RIV is a scam because no one will get 61Mp worth of resolution when shooting people in moderate lighting without flash. Marketing obviously completely omit to tell about that.
In reality, you're not going to observe shutter shock across the entire 1/20 - 1/180s range, nor with every lens. When it occurs, it'll be most apparent at one or two shutter speeds, on specific lenses and - if they're zooms - probably at specific focal length settings or ranges where the distribution of mass is "just so". Getting to know the combinations where it happens, and at what shutter speeds, with a specific camera and lens combo allows us to work around this quirk. Sometimes, changing your grip will work. Other times, adding or removing mass (battery grip, tripod plate, etc.) will be enough to circumvent the issue, or move where it occurs.
This reminds me somewhat of "dead spots" with guitars. You can take a beautifully crafted, $5,000 hand-made instrument, play it, and find that there's a dead spot - one note on a specific string and fret - where there's little resonance and sustain. It's a lot more common than you'd think, actually. There are a couple of options for the owner... play around it so that you use that note infrequently on its own, or try adding mass to the neck or body (you can buy clip-on or clamp-on devices for this very purpose - or sometimes, a spring capo is sufficient). Of course, that changes the resonance of the entire instrument, so it's not always an ideal solution. But, hey, nothing's perfect, right?
The Sony A7R MkIV is no more a scam than any other piece of equipment. All cameras have limitations. All cameras with moving shutters have the potential for this limitation in certain circumstances. As photographers, we work around the limitation as we would any other. Is it frustrating? Sure. Is it the end of the world? No...
