Originally posted by raider How do i avoid the plane/sky either turn up too dark or too bright? what EV value should i dial in?
He's right....your position in relation to the sun is the secret. If it's cloudy, you just have to find what works. You may want to try bracketing. Your test shots don't look bad at all!
Keep in mind that you can also post-process them in Photoshop (if you have it) or similar software if your aircraft is underexposed. This way you get a properly exposed sky and you just bump up the shadows a bit and presto. For this, it's better underexposed than overexposed...as it always is.
The best advice over anything else is to HAVE FUN! I mean after all, those are folks strapping themselves into metal flying machines with loud and powerful engines, hurling themselves through the atmosphere! How cool is that! And so you can appreciate it even more....I'm a professional pilot and have done that stuff!.....and I STILL find it exhilirating just to watch! It never gets old! Even the absolutely worst photographic day at an airshow is STILL a day at the airshow!
It's real easy when you are new at anything to get frustrated and obsessed with perfection. Just remember it's your first airshow and try to do your best...but in the end, your first at anything is really nothing more than practice for the next one. Just remember to document what you did well and what you didn't do well. That way, you learn from the practice.
Now go out there, kick the tires and light the fires!
