04-18-2020, 02:01 PM   #1
rml63's Avatar
Struggling with Low Key Outside
I have been trying to figure out what would be the best set up for low key shots outside. I am interested in doing low key shots of farm machinery , barns and out buildings during the day. I have a Pentax K1 with all M lens . So TTL and HSS are probably no in my future.
My ideas so far really break down into 2 camps.
1 a pair of godox ad 200 pro with a soft box (magmod or the like)
2 a ten stop ND filter to really help crush the ambient light (since I will be limited to about 1/200 shutter speed)
3 a remote trigger with single pin firing (Thanks Javier)
The second idea I had is as follows
Led lights Litra studio with a soft box maybe x 2
I wonít need and Nd filter since I can set the shutter speed well above 1/200
I wonít need a remote trigger since I will be seeing the exposure in real time.
Do either of these setups seem correct or am I way off ?
If I were to go the strobe route do I need something bigger than an AD200 like the AD 600 to use outside in bright sun?
Thanks for your help.
Mike
04-18-2020, 03:12 PM   #2
Paul the Sunman's Avatar
Sounds like fun Mike. Good luck and show us some results when you have them.
I've only played with this sort of thing a few times. I am absolutely no expert. My (indoor) experience though is that one light source with soft box is often sufficient; with low key images, you generally do not want fill-in from multiple angles. However, I have obtained pleasing results with a main light from the front (off-centre) and one directly behind the subject. It worked well with a crystal vase and flowers.
The ND filter sounds like a good idea. I haven't tried that.
ad, box, camera, filter, photography, shots, shutter, technique, thanks
Struggling with new lens - not sure whatís the issue mtngal Troubleshooting and Beginner Help 13 04-10-2020 07:09 PM
Struggling Sprout BigDave Monthly Photo Contests 4 11-11-2019 07:34 AM
Struggling with lightweight 2 body 3 lens travel kit johnha Film SLRs and Compact Film Cameras 21 08-22-2019 11:35 PM
First attempts at high-key and low-key: question about histograms Guizo Photographic Technique 7 04-28-2014 08:00 PM
Da Lens Prices ! Low Low Low 247nino Pentax SLR Lens Discussion 41 04-14-2008 11:55 AM
All times are GMT -7. The time now is 10:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
