Originally posted by StiffLegged Could you recommend a suitable loupe to view these images at dot pitch resolution? – I feel somehow I'm missing out on proper evaluation of monster prints.
Yes, I have two: one is x15 (I can see the dots of the inkjet printer, I can also see the laser steps of the light-jet machine), the other one is x 2 and x 5. I'm not using any of these for looking at a 40"print, I'm standing 20" away, and I can't see any pixel at all, but I do see diffraction blur at f10, it looks like a test print I made at 125 PPI. => half of pixels are wasted
---------- Post added 22-04-20 at 22:08 ----------
Originally posted by BigMackCam The issue isn't whether the OP's desires are achievable (clearly they are), but that he's expecting to achieve them with his current equipment (which isn't going to happen)
I don't know. I'm thinking about how far I can stretch my system , since I'm not going to spend 50K Euros into a Phase One system. For example it came to my mind that I could do aperture brackering: take 4 shots of the same scene at f5.6, f8, f11, f16. The f16 increase the DoF to give me the foreground in focus (with some amount of diffraction). The f11 narrows a bit DoF but decrease diffraction of f16 where f11 is in focus. etc... etc... Since my camera hasn't moved for each of the 4 shots, I should have to layer them and mask portions of frames depending on DoF and f number. I can combine with pixel shift. So in the center I max out sharpness, in the foreground sharpness is not the best but better than if it was out of focus.
---------- Post added 22-04-20 at 22:14 ----------
Some ideas given in this thread are worth considering, such as tilting the camera forward. That's one option. It good to understand options and limitation, so that we have more choices in the field.
