Originally posted by atyab How about changing lenses while walking on a street and stuff? What are the things I should take care of and which equipment should I have just in case some dust does go in? I read about the air blower. Anything else?
I do it all the time. Just make sure you are semi-coordinated and don't drop the lens on the street. I have a lens pen that I used to brush dust off the front and rear elements when I notice it, but 99% of the time, you won't even notice the dust. Just don't use your fingers, the oils will make cleanup much harder.
Quote: I am also now thinking of buying a second hand lens. What are the things I should be aware of?
I wouldn't buy a lens without seeing a couple pictures of it. It's always a crapshoot, but no more so than buying new off of Amazon.
Quote: Is changing lenses while doing travel photography really an inconvenience?
No. As long as you can anticipate what lens you'll need for the next shot, it won't take more than about 15 seconds (tops) to change lenses. If you have to take a backpack off, kneel down, go through the bag, it will take much longer. I use a shoulder bag, and soon a sling bag, so changing lenses is a simple matter of reaching in for what I need.
If you think about it, most of what you'll be shooting while traveling will be static subjects (buildings, landscapes, museum pieces), or people. Unless you are shooting something fast paced, you'll have plenty of time to switch lenses if needed.
