Hello, long time no see.
I recently thought about improving my skills in macrophotography and wanted to try some techniques 'pros' use. I've stumbled upon Thomas Shahan videos on Youtube and since he uses quite motivating and cheap setup, I thought I will try to find the lens.
Today I received old and manual
SMC Pentax 50mm 1.7 which was shown on the video along with old Foca extension tubes 36+20+12mm (I'm amazed on the condition of both). It appeared I'm missing the right reverse ring (guess the lense is 49mm), but I tried to just keep the lense at the end of the extension tubes just shot a few frames for test.
I've discovered... whether the lens is mounted reversed or not, there seems to be no real difference in the maginification ratio. And so I started wondering - what are the advantages of an reversed lense on an extension tube? Did I stumble upon a false positive due to the length of the extension tubes perhaps?
Reason: added link to the lense mentioned in post
