Originally posted by Aaron28
Originally posted by MossyRocks
I don't bother with the interval shooting option. Instead I put the camera into the high continuous shooting mode and with my release cable I just flip a switch and let it shoot until I am sick of being out. There is less of a delay between shots doing it this way and you don't have to worry about going and resetting things or interrupting the interval shooting process.
the on board intervalometer was a good selling point when i got the K-50 a few years back......the 2 seconds doesn't seem to cause much trouble when stacking with starstax....not even noticeable when using gap filling or comet trail.......generally take a few shots when setting up....first i take care of whatever i can do for a decent foreground shot and sometimes stop down to f5.6 but not often.......then take a few to set the exposure that will run the duration of the interval session.....usually around an hour or so (120-150 frames) depending how long i'll hang around....cap the lens and get 10-20 darks....been a long long time since i've done any over 35mm........typically 14, 15, 21, 28, or 35
Hi Aaron, on KP you can set your Standby Interval to "Minimal". This is certainly faster than 2 sec, it feels as if it's taking about a second between the end of exposure and the start of the next exposure. Maybe the same thing is available on K-50?
And Mossy, Aaron, I know you were not talking about Astrotracer, but when I use it, burst shooting is unavailable but interval shooting with Standby Interval setting is. The following shot (cross posted
Post Your Best KP Shots - Page 166 - PentaxForums.com) was shot that way, of course stacking many exposures.
The "Mystery Satellite" turns out to be French military satellite CSO 1 BTW. I choose not to remove it and instead manually blended it in, together with the meteor that almost "hit" Andromeda.
